[GRASS-user] error running digitzing tool wxpython
Joop Goedbloed
jlgoedbloed at hetnet.nl
Mon Nov 24 04:09:05 EST 2008
Hello Users-Group
Doing some research the error below has something to do with the settings.
I've set the snapping on 10 and save the settings.
The tool runs more better but slower then v.digit (tcltk)
the tool differs also from the v.digit tool
Here is a link to three images.
img1 <ftp://80.61.251.86/grass64/J09v_digit.jpg>
img2 <ftp://80.61.251.86/grass64/J09map_display.jpg>
img3 <ftp://80.61.251.86/grass64/J09wxpython_tool.jpg>
A map with paved areas of roads:
J09v_digit.jpg (v.digit map) every boundary is green with centriods in
each paved area.
J09map_display.jpg is th same map in the display this is correct.
J09wxpyton_tool.jpg (same map wit the wxpython tool with the setting
areas cheched 'on'
This map is not correct.
here is the link
maps <ftp://80.61.251.86/grass64/>
What is wrong
Joop Goedbloed
Martin Landa schreef:
> Hi,
> 2008/11/21 Joop Goedbloed <jlgoedbloed op hetnet.nl>:
>> Grass6.4 is configured with --with-cxx --with-python --with-wxwidgets
>> The wx digitizing tool runs fine zoomin and zoom out is running fine.
>> as soom when I edit some vertex like movevertex splitvertex etc. the tool
>> seems to hang and I become this errors.
> I will check it ASAP, I am out of the office right now. So, you open
> vector map for editing, choose vertex to be moved by left mouse
> button, error appears... Is it right?
> Martin
