[GRASS-user] How to copy vector columns between databases
peter.loewe at gmx.de
Tue Nov 25 10:29:15 EST 2008
I have a vector layer FOO which is linked to two tables in layers 1 and 2.
The categories for each vector element are different in layer 1 and (e.g. a certain area may have the cat value "51" in layer 1 and a cat value of "42" in layer 2).
Let's assume that layer one has a VARCHAR column containing the names of the region (e.g. database_layer_1: 51,"Wolfenstein" database_layer_2: 42 )
If a new VARCHAR column is added to layer 2 by v.db.adcol,
how can the the names from layer 1 be copied into it?
[Goal: database_layer_1: 51,"Wolfenstein" database_layer_2: 42,"Wolfenstein" ]
Unfortunately, v.db.update seems only to work within one layer.
An UPDATE/SELECT SQL-statement will not be possible unless a table can be produced which holds the categories for both database layers for each geometry element.
How can this be solved ?
Regards,
Peter
Dr. Peter Löwe
<peter.loewe at gmx.de>
Sensationsangebot nur bis 30.11: GMX FreeDSL - Telefonanschluss + DSL
für nur 16,37 Euro/mtl.!* http://dsl.gmx.de/?ac=OM.AD.PD003K11308T4569a
