[GRASS-user] Going back to 6.3
Kurt Springs
ferret_bard at mac.com
Tue Nov 25 23:33:09 EST 2008
On Nov 25, 2008, at 8:22 PM, William Kyngesburye wrote:
> On Nov 25, 2008, at 6:53 PM, Kurt Springs wrote:
>> I hate to say it, but I need to go back to GRASS 6.3. GRASS 6.4-
>> svn keeps on freezing or unexpectedly quitting when I do anything
>> more intense than view what I've already created.
> Can you reproduce it and describe it using the spearfish sample
> data? I can check if it's a build problem.
I tried but it seemed all right with spearfish. Is there something
specific I could test. I tried working with the digitizer but I ran
into a problem I mentioned earlier. Active Tcl doesn't seem to have a
way to set the mouse button emulations. I tried the control, command
and option/alt keys to no avail. I have a Logitech mouse, and I have
left right and middle buttons set, but that didn't seem to help.
Could you shed some light on what to do?
>> Will it be as simple as dumping Active Tcl (the Wish components)
>> and reinstalling GRASS 6.3?
> If you are using my GRASS 6.3, there is no need to delete
> ActiveTcl. It has its own internal TclTk X11 binaries that it
> explicitly uses. In fact, no need to delete 6.3 before installing
> 6.4.
6.4 actually overwrote 6.3. I'd assumed the reverse would be true.
>> Also, the surface raster I generated from the ASCII files only
>> displays white now. Is there anyway to recover that once I go back
>> to 6.3?
> Rasters should be compatible between 6.4 and 6.3.
Something when v.digit crashed actually made it unreadable.
>> Kurt
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> First Pogril: Why is life like sticking your head in a bucket filled
> with hyena offal?
> Second Pogril: I don't know. Why IS life like sticking your head in
> a bucket filled with hyena offal?
> First Pogril: I don't know either. Wretched, isn't it?
> -HitchHiker's Guide to the Galaxy
