[GRASS-user] Going back to 6.3
William Kyngesburye woklist at kyngchaos.com
Tue Nov 25 23:51:48 EST 2008
On Nov 25, 2008, at 10:33 PM, Kurt Springs wrote:
>> If you are using my GRASS 6.3, there is no need to delete
>> ActiveTcl.  It has its own internal TclTk X11 binaries that it
>> explicitly uses.  In fact, no need to delete 6.3 before installing
>> 6.4.
> 6.4 actually overwrote 6.3.  I'd assumed the reverse would be true.
Odd, GRASS 6.3 and 6.4 have different names:
GRASS-6.3.app
GRASS-6.4.app
>>> Also, the surface raster I generated from the ASCII files only
>>> displays white now.  Is there anyway to recover that once I go
>>> back to 6.3?
>> Rasters should be compatible between 6.4 and 6.3.
> Something when v.digit crashed actually made it unreadable.
Also odd - why a vector would affect a raster.  Or did you mean
surface _vector_?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the
past isn't a fiction designed to account for the discrepancy between
my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
