[GRASS-user] Best way to reconnect tables in grass' databse
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Thu Nov 27 18:16:46 EST 2008
On Thu, 2008-11-27 at 13:09 +0100, Nikos Alexandris wrote:
> On Thu, 2008-11-27 at 09:33 +0100, Markus Neteler wrote:
> > hi Nikos,
> > On Thu, Nov 27, 2008 at 1:32 AM, Nikos Alexandris
> > <nikos.alexandris at felis.uni-freiburg.de> wrote:
> > > Your explanation(s) are, as usual, precise. The parameter's names are
> > > very clear. I got confused somehow from the fact the "v.db.connect -g"
> > > prints out several "variables" and the help-text of "v.db.reconnect.all"
> > > contains the word "variables" as well. So I stuck in "plural" :-?
> > > My mistake of course. But adding your words *the string which appears as
> > > the fourth field of "v.db.connect -g"* (or some other text) in
> > > v.db.reconnect.all's description/help can't harm anyone.
> > > Or maybe an example, in my case using sqlite as a DBMS, (for future
> > > grass-adventurer's ;-):
> > > v.db.reconnect.all
> > > old_database="/home/nik/grassdb/peloponnese/hgrs87/PERMANENT/sqlite.db"
> > > new_database="/geo/grassdb/peloponnese/hgrs87/PERMANENT/sqlite.db"
> > Can you please submit a diff against SVN with the document change?
> > Then it is 100 times easier to merge that in :) Since you are power user
> > I am sure that creating a diff is no big deal for you, see
> > http://trac.osgeo.org/grass/wiki/HowToSVN#LocalDiffs
> > Thanks,
> > Markus
> Hi Markus!
> Sure, I will do so.
> Thank you, Nikos
This seem to require another treatment... ?
# editing the file and saving changes
nik at vertical:/usr/local/src/grass6_devel$ nano
scripts/v.db.reconnect.all/v.db.reconnect.all.tmp.html
# excute svn diff to check changes
nik at vertical:/usr/local/src/grass6_devel$ svn diff
No output!!
What am I doing wrong?
Is something, due to the ".tmp.html" ending, different?
Nikos
