[GRASS-user] Best way to reconnect tables in grass' databse
    Nikos Alexandris
    nikos.alexandris at felis.uni-freiburg.de
    Fri Nov 28 07:33:23 EST 2008
On Fri, 2008-11-28 at 02:52 +0000, Glynn Clements wrote:
> Nikos Alexandris wrote:
> > > > This seem to require another treatment... ?
> > > > # editing the file and saving changes
> > > > nik at vertical:/usr/local/src/grass6_devel$ nano
> > > > scripts/v.db.reconnect.all/v.db.reconnect.all.tmp.html
> > > This is the temporary file, not the file in SVN (which
> > > is description.html in 6.x and modulename.html in 7).
> > > Just copy over your changes into the right html file and
> > > svn diff will work.
> > > Markus
> > Well, I thought so (that description is the file to be edited) but it
> > (=description.html) has only one sentence in it:
> Yep, that's the one.
> Everything prior to the "<H2>DESCRIPTION</H2>" line is generated by
> the parser:
> 	v.db.reconnect.all --html-description
> The Makefile rules merge this with the contents of the
> description.html file to get the completed HTML documentation.
> This approach guarantees that the flags and options at least have
> accurate (if somewhat minimal) documentation, even if the rest of the
> documentation is hopelessly out of date.
> > Anyhow, I'll copy the whole file (I think it's not wrong -- or is it?)
> It is. Don't copy the boilerplate from the top of the .tmp.html file
> into the description.html file.
OhOh... too late. Sorry, I'll correct it. Excuse my ignorance.
Nikos
