[GRASS-user] Re: Gui error behind splash screen
Daniel Victoria
daniel.victoria at gmail.com
Sat Nov 29 08:32:15 EST 2008
another update. I can get into a lat lon location in the grass
terminal but g.region -p gives me a segmentation fault
On Sat, Nov 29, 2008 at 11:26 AM, Daniel Victoria
<daniel.victoria at gmail.com> wrote:
> An update. Just found out that everything works fine with an UTM
> location but, the failure happens when I try a lat-lon location.
> Here is my wind file:
> proj: 3
> zone: 0
> north: 7S
> south: 15S
> east: 57W
> west: 67W
> cols: 3704
> rows: 2963
> e-w resol: 0:00:09.719222
> n-s resol: 0:00:09.719879
> top: 1
> bottom: 0
> cols3: 1
> rows3: 1
> depths: 1
> e-w resol3: 1
> n-s resol3: 1
> t-b resol: 1
> Don't see anything wrong...
> Daniel
> On Fri, Nov 28, 2008 at 4:45 PM, Daniel Victoria
>> Hi all,
>> I just installed grass6.3 from les-ejk repository on a very striped
>> down ubuntu machine and I can create the location and mapset with no
>> problem in the GUI. The problem is that, after I create the mapset and
>> grass tries to load the gis.m it gives me an error message which I can
>> not see because it's behind the splash screen.
>> Could it be a tcl/tk version problem? I believe I have both 8.4 and
>> 8.5. On the other hand, the location chooser gui works fine...
>> Thanks
>> Daniel
