[GRASS-user] [Fwd: grass-related failure when building qgis_0_11]
    Nikos Alexandris
    nikos.alexandris at felis.uni-freiburg.de
    Sat Nov 29 15:16:57 EST 2008
On Sat, 2008-11-29 at 18:26 +0100, Markus Neteler wrote:
> On Mon, Nov 24, 2008 at 6:24 PM, Nikos Alexandris
> <nikos.alexandris at felis.uni-freiburg.de> wrote:
> > ---------- Forwarded message ----------
> > From: Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>
> > To: grass-dev at lists.osgeo.org
> > Date: Mon, 24 Nov 2008 07:49:10 +0100
> > Subject: grass-related failure when building qgis_0_11
> > Hi all! I get this error when building qgis 0.11 from source. I've read
> > the http://trac.osgeo.org/grass/ticket/364 ticket. Is it really fixed?
> > This problem does not occur when building qgis preview version.
> > [ 71%] Building CXX object
> > src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrassprovider.o
> > /usr/local/grass-6.4.svn/include/grass/Vect.h: In static member function
> > 'static int QgsGrassProvider::openMap(QString, QString, QString,
> > QString)':
> > /usr/local/grass-6.4.svn/include/grass/Vect.h:197: error: too many
> > arguments to function 'int Vect_build(Map_info*)'
> > /usr/local/src/qgis_0_11_0/src/providers/grass/qgsgrassprovider.cpp:1040: error: at this point in file
> > /usr/local/grass-6.4.svn/include/grass/Vect.h: In member function 'bool
> > QgsGrassProvider::closeEdit(bool)':
> > /usr/local/grass-6.4.svn/include/grass/Vect.h:199: error: too many
> > arguments to function 'int Vect_build_partial(Map_info*, int)'
> > /usr/local/src/qgis_0_11_0/src/providers/grass/qgsgrassprovider.cpp:1495: error: at this point in file
> > /usr/local/src/qgis_0_11_0/src/providers/grass/qgsgrassprovider.cpp:1496: error: at this point in file
> > make[2]: ***
> > [src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrassprovider.o] Error
> > 1
> > make[1]: *** [src/providers/grass/CMakeFiles/qgisgrass.dir/all] Error 2
> > make: *** [all] Error 2
> I have backported the needed GRASS provider changes from QGIS-trunk
> to 0.11.svn and sent to the QGIS people for integration.
> Markus
Thanks to Markus it works now :-)
Nikos
