[GRASS-user] Point vector aggregation to raster
Thu Oct 2 17:20:09 EDT 2008
Gustavo Martinez wrote:
> I have a vector layer with several thousand points from which I need to create
> a raster containing the sum of an attribute of the points covered by each
> cell. How can I do this? In the documentation of v.to.rast there is no
> indication of the way it converts from point to cell.
You should be able to do this using v.out.ascii and r.in.xyz.
