[GRASS-user] connect to postgreSQL
Jhon Ortiz
eljhonjhon at hotmail.com
Sat Oct 4 12:43:41 EDT 2008
> On 04/10/08 16:39, Stanislav Bek wrote:
>> Hi,
>> I have problem to connect to postgreSQL server from grass.
>> GRASS 6.3.0 (opava):~> psql -l
>> List of databases
>> Name | Owner | Encoding
>> gis1 | bekas | UTF8
>> postgres | postgres | UTF8
>> template0 | postgres | UTF8
>> template1 | postgres | UTF8
>> (4 rows)
>> GRASS 6.3.0 (opava):~> db.connect driver=pg database=gis1
>> GRASS 6.3.0 (opava):~> db.test test=test1
>> create table grass_test1 (i1 integer, d1 double precision, c1 varchar(20))
>> DBMI-Postgres driver error:
>> Cannot connect to Postgres: could not connect to server: No such file or directory
>> Is the server running locally and accepting
>> connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
in the error said, the server is running locally..
Try
GRASS 6.3.0 (opava):~> db.connect driver=pg database="host=localhost,dbname=gis1"
db.login user=your user pass=your password
db.connect -p
db.tables -p
if not is connection posible. follow you the advice Moritz
John
>> ERROR: Unable to open database
>> ERROR: EXECUTE: ******** ERROR ********
>> etc.
>> I use PostgreSQL 8.3.3.
>> Don't you have an idea why it is not working?
> The error message is quite clear:
> "could not connect to server: No such file or directory
> connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?"
> This is a PostgreSQL issue (you will probably get the same message if
> you try to connect with 'psql -h localhost gis1').
> This means that PostgreSQL is not installed to accept connections via
> tcp/. You can change that in the relevant config file (probably
> something like /etc/postgresql/8.3/main/postgresql.conf - but that
> depends on your distribution).
> Moritz
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
_________________________________________________________________
¡Entra en el Club oficial de Messenger y te enterarás de todas las novedades!
http://www.vivelive.com/ilovemessenger
