[GRASS-user] connect to postgreSQL
Glynn Clements
glynn at gclements.plus.com
Sat Oct 4 21:59:32 EDT 2008
Stanislav Bek wrote:
> I have problem to connect to postgreSQL server from grass.
> GRASS 6.3.0 (opava):~ > psql -l
> List of databases
> Name | Owner | Encoding
> gis1 | bekas | UTF8
> postgres | postgres | UTF8
> template0 | postgres | UTF8
> template1 | postgres | UTF8
> (4 rows)
> GRASS 6.3.0 (opava):~ > db.connect driver=pg database=gis1
> GRASS 6.3.0 (opava):~ > db.test test=test1
> create table grass_test1 (i1 integer, d1 double precision, c1 varchar(20))
> DBMI-Postgres driver error:
> Cannot connect to Postgres: could not connect to server: No such file or directory
> Is the server running locally and accepting
> connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
Try:
db.connect driver=pg database="host=localhost,dbname=gis1"
to connect using TCP.
Also, "netstat -ax" will list active Unix-domain sockets. If
postmaster is accepting local (Unix-domain) connections, its socket
will be listed there. E.g. I have:
unix 2 [ ACC ] STREAM LISTENING 3442 /tmp/.s.PGSQL.5432
If it's listening on a Unix-domain socket, check that you have the
necessary permissions on both the socket and its parent directories.
