[GRASS-user] SRTM data aliases in UTM
John Stevenson john.stevenson at manchester.ac.uk
Mon Oct 6 08:20:07 EDT 2008
I have imported some tiles of 1 arcsecond SRTM data into GRASS 6.3 using
r.in.srtm into a lat-long region.  Whenever I import them to a UTM
region, res=30, I get aliasing problems.  This results in a grid of
lines of jumps in elevation running through my data.
This happens when I use r.proj.  I have also tried generating a text
file of UTM coordinates via r.stats -1g, and cs2cs.  Importing this as a
raster or vector, and interpolating with r.surf.rst or v.surf.rst also
give aliasing errors.
What is the best way round this?  Importing at a higher resolution?  How
much higher?  My ultimate aim is to compare the SRTM with LiDAR data, so
if possible I would like to use an exact interpolation where possible.
Cheers
John
Dr John Stevenson
Postdoctoral Research Associate
School of Earth, Atmospheric and Environmental Sciences
Williamson Building (Room 2.42)
University of Manchester
Manchester M13 9PL, UK
tel. +44(0)161 306 6585; fax. +44(0)161 306 9361;
