[GRASS-user] flip raster
    Glynn Clements
    glynn at gclements.plus.com
    Mon Oct  6 20:37:34 EDT 2008
José María Michia wrote:
> I've imported a NetCDF file (ETOPO1 model). The resulted raster appears
> flipped vertically. How can I fix this? I try with mapcalc, without success:
> - neighborhood modifier: not accept computations in offset parameter, like
> map[0,total_rows-row()]
> - I dont know how to query map in arbitrary coordinates, like
> map(x(),-1*y())
There isn't any mechanism in r.mapcalc to achieve this. I'm not sure
that it's possible to do it entirely within GRASS. Flipping
geo-referenced data doesn't really make much sense.
Either figure out how to import it with the correct orientation, or
export it, flip the exported data, then re-import.
