[GRASS-user] importing L1G-data into GRASS
rosa
rosa.marzipan at gmx.de
Tue Oct 7 10:13:31 EDT 2008
hi
I've tested and missed r.in.gdal, but never heared of hdf-support. is that
something i have to instell separately? any instructions how? and who is
glynn?
thanks,
rene
Am Montag 06 Oktober 2008 17:43:05 schrieb Otto Dassau:
> Hi,
> On Mon, 6 Oct 2008 17:00:16 +0200
> maybe you already tested and missed it but have you tried to import your
> data with r.in.gdal (using GDAL with HDF support) as suggested by Glynn?
> kind regards,
> Otto
> > rene
> > Am Montag 06 Oktober 2008 09:34:03 schrieb Niels Thevs:
> > > Dear Irene,
> > > when you display one channel in GRASS, it is displayed by default with
> > > a color scheme ranging form green to yellow or blue to red. Under
> > > Raster -> Manage Map Color you can change this.
> > > Regarding the import of Landsat images I prefer the following way,
> > > though not purely with open source software: Import your image with
> > > ERDAS and save it as img-file. img is a rather wide spread satellite
> > > image data format, which can be read inmediately by ERDAS, ENFI, ARC
> > > GIS etc. And, img.-files can be imported without any problems into
> > > GRASS. You even can build your location with a few clicks using an img
> > > file.
> > > I guess that in Potsdam there is an ERDAS Licence somewhere.
> > > Best regards
> > > Niels
> > > rosa schrieb:
> > > > hello,
> > > > i'm new on this list since yesterday.
> > > > some postgraduates are trying to introduce GRASS in our university
> > > > and so I'm writing one of the first thesis' with GRASS. Unfortunately
> > > > nobody here knows the program really well.
> > > > I bought a landsat scene, recieved it in hdf.L1G-format and have
> > > > problems importing landsat the hdf.L1G-data into GRASS. r.in.bin does
> > > > somehow work, but the channels it imports are severely damaged.
> > > > instead of having the normal black/white picture, the chanels are
> > > > only green and yellow and it's not possible to combine them, f.e.
> > > > with r.composite.
> > > > does anybody know the problem?
> > > > warm regards from potsdam, germany
> > > > irene
> > > > _______________________________________________
> > > > grass-user mailing list
> > > > grass-user at lists.osgeo.org
> > > > http://lists.osgeo.org/mailman/listinfo/grass-user
