[GRASS-user] New r.what.vect.buffer addon module [was: query by distance]
Dylan Beaudette dylan.beaudette at gmail.com
Thu Oct 9 19:57:26 EDT 2008
On Thursday 09 October 2008, Hamish wrote:
> Edmondo:
> > > there is an easy way to select (on a raster map) all features into a
> > > certain radius from a specific point?
> Nikos:
> > Maybe something using r.buffer/v.buffer --> YourBuffer (rasterize if it
> > comes from v.buffer), then r.mapcalc MASK=YourBuffer, then operate
> > within the MASK?
> Hi,
> fyi I've recently added a new addon module called r.what.vect.buffer.
>   http://grass.osgeo.org/wiki/GRASS_AddOns#v.what.rast.buffer
> The idea is to provide local environmental context to a series of vector
> points.
> v.what.rast or r.what + coord alone may return a spike in the raster data
> without you knowing. What this script does is create a buffer around each
> vector point and gather some stats about the raster cells nearby and
> report them in a .csv table. Multiple raster maps can be sampled.
> I assume the location is not lat/lon, and (in column names) that units
> will be meters. (r.buffer would be lat/lon safe; but I used r.circle
> because it allows starting from an exact coord not from the nearest cell)
> v.rast.stats + v.buffer is problematic when input points' buffers overlap.
> GRASS> v.what.rast.buffer --help
> Description:
>  Calculates univariate statistics of raster map(s) from buffers around
> vector points. Results are written to a file. Resolution is taken from each
> input map.
> Keywords:
>  vector, raster, statistics
> Usage:
>  v.what.rast.buffer input=name raster=name[,name,...] buffer=value
>    [output=name] [fs=character] [--verbose] [--quiet]
> Flags:
>  --v   Verbose module output
>  --q   Quiet module output
> Parameters:
>    input   Points vector map containing query positions
>   raster   Name of raster map(s) to calculate statistics from
>   buffer   Buffer distance in map units
>            default: 100
>   output   Name for output file (if omitted or "-" output to stdout)
>       fs   Field separator in output file
>            default: |
> spearfish example:
>   v.what.rast.buffer in=archsites rast=elevation.dem,slope out="-"
> enjoy,
> Hamish
Interesting! This functionality is also StarSpan, albeit not within a
raster-only context. It would be interesting to compare the results!
Cheers,
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
