[GRASS-user] g.rename in a loop has no real effect
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Sat Oct 11 18:21:49 EDT 2008
(using GRASS 6.4.svn under Ubuntu 64-bit)
~/PERMANENT/cell > ls -l
total 804220
-rw-r--r-- 1 nik nik 1135311 2008-10-10 04:10 composite_28082007_b742
-rw-r--r-- 1 nik nik 21633788 2008-10-10 02:47
L71183034_03420070828_B10
-rw-r--r-- 1 nik nik 21893170 2008-10-10 02:48
L71183034_03420070828_B20
-rw-r--r-- 1 nik nik 22822290 2008-10-10 02:48
L71183034_03420070828_B30
-rw-r--r-- 1 nik nik 21133756 2008-10-10 02:48
L71183034_03420070828_B40
-rw-r--r-- 1 nik nik 22834132 2008-10-10 02:49
L71183034_03420070828_B50
-rw-r--r-- 1 nik nik 9470878 2008-10-10 02:49
L71183034_03420070828_B61
-rw-r--r-- 1 nik nik 23574756 2008-10-10 02:49
L71184034_03420070904_B10
-rw-r--r-- 1 nik nik 24291516 2008-10-10 02:50
L71184034_03420070904_B20
-rw-r--r-- 1 nik nik 25511638 2008-10-10 02:50
L71184034_03420070904_B30
-rw-r--r-- 1 nik nik 24389358 2008-10-10 02:50
L71184034_03420070904_B40
-rw-r--r-- 1 nik nik 27081802 2008-10-10 02:51
L71184034_03420070904_B50
-rw-r--r-- 1 nik nik 12005030 2008-10-10 02:51
L71184034_03420070904_B61
-rw-r--r-- 1 nik nik 10783979 2008-10-10 00:59
L72183034_03420070828_B62
-rw-r--r-- 1 nik nik 49431852 2008-10-10 00:59
L72183034_03420070828_B70
-rw-r--r-- 1 nik nik 196734858 2008-10-10 00:59
L72183034_03420070828_B80
-rw-r--r-- 1 nik nik 11040917 2008-10-10 00:59
L72184034_03420070904_B62
-rw-r--r-- 1 nik nik 49589402 2008-10-10 01:00
L72184034_03420070904_B70
-rw-r--r-- 1 nik nik 197905262 2008-10-10 01:00
L72184034_03420070904_B80
-rw-r--r-- 1 nik nik 48443802 2008-10-09 23:32 landsat_04092007_b1
-rw-r--r-- 1 nik nik 748160 2008-10-10 02:46 MASK
-rw-r--r-- 1 nik nik 225332 2008-10-10 02:45 StudyArea
[Raster MASK present]
PERMANENT/cell > for x in L7*; do g.rename rast=$x,`echo $x | tr
'[:upper:]' '[:lower:]'`; done
Rename raster <L71183034_03420070828_B10> to <l71183034_03420070828_b10>
Rename raster <L71183034_03420070828_B20> to <l71183034_03420070828_b20>
Rename raster <L71183034_03420070828_B30> to <l71183034_03420070828_b30>
Rename raster <L71183034_03420070828_B40> to <l71183034_03420070828_b40>
Rename raster <L71183034_03420070828_B50> to <l71183034_03420070828_b50>
Rename raster <L71183034_03420070828_B61> to <l71183034_03420070828_b61>
Rename raster <L71184034_03420070904_B10> to <l71184034_03420070904_b10>
Rename raster <L71184034_03420070904_B20> to <l71184034_03420070904_b20>
Rename raster <L71184034_03420070904_B30> to <l71184034_03420070904_b30>
Rename raster <L71184034_03420070904_B40> to <l71184034_03420070904_b40>
Rename raster <L71184034_03420070904_B50> to <l71184034_03420070904_b50>
Rename raster <L71184034_03420070904_B61> to <l71184034_03420070904_b61>
Rename raster <L72183034_03420070828_B62> to <l72183034_03420070828_b62>
Rename raster <L72183034_03420070828_B70> to <l72183034_03420070828_b70>
Rename raster <L72183034_03420070828_B80> to <l72183034_03420070828_b80>
Rename raster <L72184034_03420070904_B62> to <l72184034_03420070904_b62>
Rename raster <L72184034_03420070904_B70> to <l72184034_03420070904_b70>
Rename raster <L72184034_03420070904_B80> to <l72184034_03420070904_b80>
total 804220
Why doesn't it work properly here?
Thank you, Nikos
