[GRASS-user] r.reclass and g.remove: another issue
Daniel Victoria daniel.victoria at gmail.com
Fri Oct 17 10:15:15 EDT 2008
I just found out that this old bug in WinGrass 6.3
The reclass_to file is not being removed after I removed the reclassed
map. So I can't remove the original map.
I also noticed that, using r.mapcalc in MSYS Console will not give the
user any feedback like that percent count
Daniel
On Fri, Apr 27, 2007 at 3:10 AM, Jarekj Jasiewicz <jarekj at amu.edu.pl> wrote:
> Glynn Clements napisał(a):
>> Glynn Clements wrote:
>>>> The problem is beacause:
>>>> in:
>>>> ~/spearfish60/nowe/cell_misc/abc
>>>> exist file reclased_to with "cdf at nowe"
>>>> if reclased_to will be removed manually base map can be removed without
>>>> problem. Unfortunatly I don't how to fix it
>>> The first g.remove should have removed the entry from the reclassed_to
>>> file; I'll look into why it didn't.
>> The code was unconditionally appending @mapset to the name, looking
>> for e.g. cdf at nowe@nowe in the reclass_to file.
>> Fixed in CVS.
> thanks
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
