[GRASS-user] WinGrass start monitor
Glynn Clements
glynn at gclements.plus.com
Sun Oct 19 07:38:25 EDT 2008
glaporta wrote:
> When I start WinGRASS 6.3 in Command line mode I'm not able to open a
> monitor. I tried with
> d.mon start=x0, but it doesn't work. Any suggestion?
Monitors don't work on Windows. If you run a d.* command, it will just
create an image (by default, a PNG file named map.png). d.* commands
which use the mouse just won't work; you'll need to see if there's
equivalent functionality in the GUI.
