[GRASS-user] Re: grass-user Digest, Vol 30, Issue 46
Van PD Tri vpdtri at ctu.edu.vn
Mon Oct 20 05:09:24 EDT 2008
Hi to all,
I can manage to install Grass into Ubuntu.
The trouble was that I was doing all steps in terminal with the active
path is in desktop. We just need to move the current path from desktop
to any other location (e.g. cd \d_drive) and do all the rest from the
intrucsion found in the website. Things are going well then.
Thanks very much for all your help.
Regards,
Tri Van
Quoting grass-user-request at lists.osgeo.org:
> Send grass-user mailing list submissions to
> 	grass-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://lists.osgeo.org/mailman/listinfo/grass-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	grass-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-user digest..."
> Today's Topics:
>    1. Re: generalize a map of points (Wolf Bergenheim)
>    2. Re: v.digit-grass64 (Martin Landa)
>    3. Re: generalize a map of points (Wolf Bergenheim)
>    4. Re: "Re: Contents of grass-user digest... HOW TO	INSTALL
>       GRASS" (Van PD Tri)
>    5. Landsat SLC-Off gap filling (Ned Horning)
>    6. Re: Landsat SLC-Off gap filling (maning sambale)
>    7. Re: Landsat SLC-Off gap filling (Hamish)
>    8. Re: examples of Web GIS interaction between citizens	and
>       governments (Eduardo corbelle)
>    9. RE: How to install Grass into Ubuntu (Jhon Ortiz)
> Message: 1
> Date: Sun, 19 Oct 2008 23:46:00 +0300
> From: Wolf Bergenheim <wolf+grass at bergenheim.net>
> Subject: Re: [GRASS-user] generalize a map of points
> To: Jos? Mar?a Michia <jose.maria.michia at gmail.com>
> Cc: grassuser <grass-user at lists.osgeo.org>
> Message-ID: <48FB9C88.3000306 at bergenheim.net>
> Content-Type: text/plain; charset=ISO-8859-1
> Jos� Mar�a,
>> If possible, I think it would be useful feature the following:
>> - Where two labels overlap, comparing an attribute to decide which one stays
>> For example: on a map of cities you can use the number of inhabitants.
>> If the city "A" has more inhabitants than the city "B", maintaining
>> the label of the city "A".
> I have just now committed a change in v.label.sa that will do exactly
> this. See the new overlap parameter. I would appreciate it if you could
> test it, and give some feedback on how it is working for you.
> Thank you,
> --Wolf
> <:3 )---- Wolf Bergenheim ----( 8:>
> Message: 2
> Date: Sun, 19 Oct 2008 22:54:30 +0200
> From: "Martin Landa" <landa.martin at gmail.com>
> Subject: Re: [GRASS-user] v.digit-grass64
> To: "Paolo Craveri" <pcraveri at gmail.com>
> Cc: grass-user at lists.osgeo.org
> Message-ID:
> 	<f8fe65c40810191354i4f22da31n95474e5edafe8168 at mail.gmail.com>
> Hi,
> 2008/10/19 Paolo Craveri <pcraveri at gmail.com>:
>> there are differences, between wx and tcltk, in the manner of which
>> v.digit depicts isles: see images
>> http://picasaweb.google.it/pcraveri/Grass64Topology#
>> Is this normal ?
> no;-)
> well, both the TCL/TK and Wx digitizer seems to me to be buggy. TCL/TK
> v.digit ignores boundaries which share two areas (shows them in green
> by default), wx digitizer shows isles as areas (i.e. boundary sharing
> area and isle as orange by defaut).
> Please correct me if needed. Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
> Message: 3
> Date: Mon, 20 Oct 2008 00:22:09 +0300
> To: Markus Neteler <neteler at osgeo.org>
> Cc: GRASS user list <grass-user at lists.osgeo.org>
> Message-ID: <48FBA501.8080104 at bergenheim.net>
> On 19.10.2008 21:49, Markus Neteler wrote:
>> On Fri, Oct 17, 2008 at 10:19 PM, Wolf Bergenheim
>> <wolf+grass at bergenheim.net> wrote:
>>> I'm still waiting for Hamish to check a patch for d.labels to allows
>>> precision placement that v.label.sa. So far he has been to busy to check
>>> it. *shrug*
>> Wolf, could you dig out the relevant link(s) or ticket?
>> Maybe we can accelerate things but I don't remember details.
> I was too lazy to go digging through mail archives so I filed a ticket
> instead (I never filed one for this issue, so I hope it's ok). The
> ticket is number 340
> http://trac.osgeo.org/grass/ticket/340
> I also uploaded fresh patches (against the current develbranch_6).
> Thanks for taking a look :)
> --Wolf
> Message: 4
> Date: Mon, 20 Oct 2008 12:51:31 +0700
> From: Van PD Tri <vpdtri at ctu.edu.vn>
> Subject: Re: [GRASS-user] "Re: Contents of grass-user digest... HOW TO
> 	INSTALL GRASS"
> To: Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>
> Message-ID: <20081020125131.rn0id9a5cgc0c0ck at webmail.ctu.edu.vn>
> Content-Type: text/plain;	charset=UTF-8;	DelSp="Yes";	format="flowed"
> Hi to all,
> Thanks Nikos!
> I have just practised your guidance (i.e. > (a) You can launch grass
> from a terminal by typing: grass -gui)
> After doing it, the following error appear:
> dtat at dtat-desktop:~$ grass -gui
> The program 'grass' is currently not installed.  You can install it
> by typing:
> sudo apt-get install grass
> bash: grass: command not found
> I wonder why because I did run the command
> And it looks like I was doing successful.
> Could you please give me further help.
> Best regards,
> Tri Van
> Quoting Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>:
>> On Mon, 2008-10-20 at 00:40 +0700, Van PD Tri wrote:
>>> Hi to all,
>>> I think I can install GRASS already. At the end, I receive a note like:
>>>   │ Operating System Distributor License for Java v1.1 (DLJ)
>>>   │ Operating System Distributor License for Java version 1.1 (DLJ)
>>>   │ SUN MICROSYSTEMS, INC. ("SUN") IS WILLING TO LICENSE THE JAVA
>>> PLATFORM    ▒
>>>   │ STANDARD EDITION DEVELOPER KIT ("JDK" - THE "SOFTWARE") TO YOU
>>> ONLY UPON  ▒
>>>   │ THE CONDITION THAT YOU ACCEPT ALL OF THE TERMS CONTAINED IN
>>> THIS LICENSE  ▒
>>>   │ AGREEMENT (THE "AGREEMENT").  PLEASE READ THE AGREEMENT
>>> CAREFULLY.  BY    ▒
>>>   │ INSTALLING, USING, OR DISTRIBUTING THIS SOFTWARE, YOU ACCEPT
>>> ALL OF THE   ▒
>>>   │ TERMS OF THE AGREEMENT.
>>> However, I have no idea where it is installed and how to launch
>>> GRASS?! Could you please send any help?
>>> Best regards,
>>> Tri Van
>> Hi!
>> I don't think(=know if) that the "Java" message has anything to do with
>> GRASS.
>> (a) You can launch grass from a terminal by typing:
>> gass -gui
>> (b) Or you want to add a new menu item (Ubuntu specific: System >
>> Preferences > Main Menu > New Item  -- then enter "grass -gui" withouth
>> the qiuotes in the "command" field, give some a name for your new
>> "launcher" and a description if you like. *** Decide under which Menu
>> you want/will place the "grass" launcher ***).
>> You might (...probably) want to read the following thread(s):
>> http://www.nabble.com/grass-gis-td19636258.html
>> http://www.nabble.com/grass-gis.-td19636354.html
>> Kind regards, Nikos
> This message was sent using IMP, the Internet Messaging Program.
> Message: 5
> Date: Mon, 20 Oct 2008 02:11:21 -0400
> From: "Ned Horning" <nedh at lightlink.com>
> Subject: [GRASS-user] Landsat SLC-Off gap filling
> To: grass-user at lists.osgeo.org
> Message-ID: <48fc2109.5de3.0 at lightlink.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Hi - Is there anyone out there who has worked on an algorithm to fill gaps in
> Landsat ETM+ SLC-Off data? Now that the Landsat 7 archive is freely available
> I am looking for an open source approach to fill the gaps in the SLC-Off data
> and GRASS seems like a good option. I'm most interested in
> multi-date approaches
> but at this stage I'm looking at single-date approaches as well. Any ideas?
> Ned
> Message: 6
> Date: Mon, 20 Oct 2008 14:47:48 +0800
> From: "maning sambale" <emmanuel.sambale at gmail.com>
> Subject: Re: [GRASS-user] Landsat SLC-Off gap filling
> To: nedh at lightlink.com
> Message-ID:
> 	<f902f9840810192347s261337c2u418f410e1736cfe at mail.gmail.com>
> +1
> I had just downloaded new Landsat 7 SLC-Off data.  It still useable
> for land use change analysis.  A grass tool would be very helpful.
> cheers,
> maning
>> in
>> available
>> data
>> and GRASS seems like a good option. I'm most interested in multi-date
>> approaches
>> Ned
> | __.-._  |"Ohhh. Great warrior. Wars not make one great." -Yoda     |
> | '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
> |  /'.-c  |Linux registered user #402901, http://counter.li.org/     |
> |  |  /T  |http://esambale.wikispaces.com|
> | _)_/LI
> Message: 7
> Date: Mon, 20 Oct 2008 00:50:25 -0700 (PDT)
> From: Hamish <hamish_b at yahoo.com>
> To: grass-user at lists.osgeo.org, nedh at lightlink.com
> Message-ID: <771886.66278.qm at web110014.mail.gq1.yahoo.com>
> Content-Type: text/plain; charset=us-ascii
>> in Landsat ETM+ SLC-Off data? Now that the Landsat 7 archive is freely
>> available I am looking for an open source approach to fill the gaps
>> in the SLC-Off data and GRASS seems like a good option. I'm most interested
>> in multi-date approaches but at this stage I'm looking at single-date
> Some ideas here:
>   http://grass.osgeo.org/wiki/MODIS#Removing_holes
> both single scene interpolation (r.fillnulls) and rolling composite
> using a time series (r.patch) methods are explained.
> Hamish
> __________________________________________________
> Do You Yahoo!?
> Tired of spam?  Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
> Message: 8
> Date: Mon, 20 Oct 2008 09:59:03 +0200
> From: "Eduardo corbelle" <eduardo.corbelle at gmail.com>
> Subject: [GRASS-user] Re: examples of Web GIS interaction between
> 	citizens	and governments
> To: "M. Fioretti" <mfioretti at nexaima.net>
> Message-ID:
> 	<276333290810200059p59d2b4aby8b12aa05f680b0c0 at mail.gmail.com>
> Marco:
> If an owner wants to offer (enter) a parcel, he/she also can do it using the
> web interface. In the same web (http://www.bantegal.com/sitegal ), the
> fourth option on the left is "ofrecer parcelas" ("offer parcels"). Once
> selected, this option guides you through several steps to locate the parcel
> (you could try: just select a province, municipality and parish, click on
> "seguir" --go on-- and a webmap will appear on which you can interactively
> click on the parcel you would like to enter). A few more clicks on "seguir"
> will show some cadastre information, a reference rent to be perceived (a
> minimum of 20 euros a year or 10 euros per hectare-year), and other.
> For a parcel to be correctly introduced in the system, the owner must
> register (a registration page would appear near the end of the process).
> Once the parcel is introduced, the administrative process is started and
> several days later the owner would be required to sign a contract on paper.
> By the way, some of the parcels already introduced in the system were
> managed by the administration, and these were introduced by public
> officials.
> 2008/10/18 M. Fioretti <mfioretti at nexaima.net>
>> On Fri, Oct 17, 2008 10:07:17 AM +0200, Eduardo corbelle wrote:
>> > Marco:
>> > Although it is not exactly what you asked for, I think the Galician Land
>> > Information System ( http://www.bantegal.com/sitegal ) recently created
>> in
>> > Spain deserves a look (unfortunately it doesn't have an English version).
>> Eduardo,
>> yes, thanks, this is an interesting use case. How do people or offices
>> who want to _lease_ unused lands to farmers enter those lands into the
>> system, and who are they? Are they only public officers?
>> Thanks,
>>        Marco
>> Your own civil rights and the quality of your life heavily depend on how
>> software is used *around* you:            http://digifreedom.net/node/84
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> http://lists.osgeo.org/pipermail/grass-user/attachments/20081020/c19ef400/attachment-0001.html
> Message: 9
> Date: Mon, 20 Oct 2008 10:10:32 +0200
> From: Jhon Ortiz <eljhonjhon at hotmail.com>
> Subject: RE: [GRASS-user] How to install Grass into Ubuntu
> To: <grass-user at lists.osgeo.org>, <vpdtri at ctu.edu.vn>,
> 	<giohappy at gmail.com>
> Message-ID: <BLU145-W2333640710B2B284417899C62F0 at phx.gbl>
>> The offical Ubuntu repositories are a bit outdated. A more updated
>> repo is the one from Jachym: http://www.les-ejk.cz/ubuntu/
>> The Gutsy one has Grass 6.3.0, updated to May 2008.
> Im working with Ubuntu 7.10 Gutsy and in this repositories
> not is available the version 6.3.0, the laster version in this
> repositories is 6.2.2  (http://www.les-ejk.cz/ubuntu/).
> The people who working in Ubuntu and want to work with
> other version have to compile it. It's not a so hard task.
> http://grass.osgeo.org/wiki/Compile_and_Install
>> If you want newer versions... you need to compile it. It's not a so
>> hard task, and we can give advices.
> _________________________________________________________________
> �Sigue el calor? Consulta MSN El tiempo
> http://eltiempo.es.msn.com/
> URL:
> http://lists.osgeo.org/pipermail/grass-user/attachments/20081020/1507b616/attachment.html
> End of grass-user Digest, Vol 30, Issue 46
