[GRASS-user] Wrong projection info after importing Geotif
Agustin Lobo aloboaleu at gmail.com
Wed Oct 22 04:34:02 EDT 2008
Hi!
I'm trying to import a geotif file
(http://user.uni-frankfurt.de/~grieser/downloads/NetPrimaryProduction/npp_CruP_All_fine_geo.zip)
I import the geotif file with:
  r.in.gdal input=/media/mifat32/MASTER_ICTA2007_2008/2008b/npp.tif
output=npp
and check the region:
alobo at alobo-laptop:~$ g.region rast=npp
alobo at alobo-laptop:~$ g.region -p
GRASS_INFO_ERROR(19559,1): region for current mapset is invalid
GRASS_INFO_ERROR(19559,1): line 9: <e-w resol:  0>
But, according to gdalinfo, the geotif file is correct:
$ gdalinfo npp.tif
Driver: GTiff/GeoTIFF
Files: npp.tif
Size is 1440, 572
Coordinate System is:
GEOGCS["WGS 84",
     DATUM["WGS_1984",
         SPHEROID["WGS 84",6378137,298.2572235629972,
             AUTHORITY["EPSG","7030"]],
         AUTHORITY["EPSG","6326"]],
     PRIMEM["Greenwich",0],
     UNIT["degree",0.0174532925199433],
     AUTHORITY["EPSG","4326"]]
Origin = (-180.000000000000000,85.000000000114397)
Pixel Size = (0.250000000000200,-0.250000000000200)
Metadata:
   AREA_OR_POINT=Area
Image Structure Metadata:
   INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (-180.0000000,  85.0000000) (180d 0'0.00"W, 85d 0'0.00"N)
Lower Left  (-180.0000000, -58.0000000) (180d 0'0.00"W, 58d 0'0.00"S)
Upper Right ( 180.0000000,  85.0000000) (180d 0'0.00"E, 85d 0'0.00"N)
Lower Right ( 180.0000000, -58.0000000) (180d 0'0.00"E, 58d 0'0.00"S)
Center      (   0.0000000,  13.5000000) (  0d 0'0.00"E, 13d30'0.00"N)
Band 1 Block=1440x1 Type=Float32, ColorInterp=Gray
Any help appreciated!
Thanks,
Agus
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
Dr. Agustin Lobo
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
