[GRASS-user] How to install Grass into Ubuntu
Moritz Lennert
mlennert at club.worldonline.be
Wed Oct 22 09:26:56 EDT 2008
On 22/10/08 14:53, Matt B wrote:
> On Mon, Oct 20, 2008 at 9:16 PM, Glynn Clements
> <glynn at gclements.plus.com <mailto:glynn at gclements.plus.com>> wrote:
> Matt B wrote:
> > I'm using Grass on ubuntu 8.04. Weird thing is that unless I run
> it "sudo
> > grass" I get a bunch of errors (and it's unusable) related to
> grass not
> > having the correct permissions to write to where I keep the data
> (ie the
> > users home directory). It's not a show stoppper at the moment and
> only
> > slightly annoying. I'm not sure why this is but I have some ideas
> to hunt
> > down when I get time. I used the standard ubuntu install and
> assume its
> > something to do with the ubuntu setup script.
> Note that GRASS won't let you select a mapset as the current mapset
> (where new files are stored) unless you own it. Write permission isn't
> sufficient.
> If you are creating a location which is to be shared by multiple
> users, you either need to create a mapset directory for each user,
> owned by the user, or grant all such users write permission on the
> location directory so that they can create their own mapset directory
> (which they will own).
> Glynn Clements <glynn at gclements.plus.com
> Thanks for the heads up on this Glynn, my problem is that I'm on a dual
> boot system and I'm storing mapsets/data on an NTFS drive. It's being
> automatically mounted with the owner set as root and read/write
> permission for everyone. If I put the data on the ext3 filesystem, it
> works. I'll mess around with fstab and mount the data drive as the
> appropriate user.
Also see this thread:
http://lists.osgeo.org/pipermail/grass-windows/2008-October/001544.html
Especially:
"I solved the problem with setting uid=my_user_name in the
fstab-file."
Moritz
