[GRASS-user] gstat in a latlon location / exit+reenter grass from a
script
John Stevenson
john.stevenson at manchester.ac.uk
Wed Oct 22 12:49:08 EDT 2008
I am using gstat within grass to calculate variograms. It works very
well in UTM locations, but now I need to use it in a lat-long location,
which it doesn't support. I am trying to think of a way round this and
decided on the following strategy:
1- export the data to a text file (r.stats -1g)
2 - reproject the data in the text file to UTM (cs2cs)
3 - use gstat to calculate the variogram of the text file
This method works, provided that I run gstat outside of GRASS. However,
I would now like to run these calculations from a batch file. I can
imagine two ways of doing this, and these are my questions:
Option 1: Trick gstat so that it thinks that it is running outside of
GRASS so that it will let me input my data from a text file. I tried
unsetting some of the GRASS variables but this didn't work. Is there a
way that I can do this?
Option 2: Get my shell script to exit from GRASS, run the gstat
commands, then return to GRASS where it left off. Is this way
possible? Alternatively, if I could get GRASS to run commands as if
from another shell then that may work, too.
Cheers
John
Dr John Stevenson
Postdoctoral Research Associate
School of Earth, Atmospheric and Environmental Sciences
Williamson Building (Room 2.42)
University of Manchester
Manchester M13 9PL, UK
tel. +44(0)161 306 6585; fax. +44(0)161 306 9361;
