[GRASS-user] Location wizard problem
Michael Barton
michael.barton at asu.edu
Fri Oct 24 13:49:41 EDT 2008
For GRASS 6.3, you should use the TclTk interface. The wxPython
interface is for testing only. This issue is fixed in the 6.4 and 7
development versions.
You might be able to simply copy the wxpython code from 6.4 to 6.3 and
have much of this work if you wanted to try it.
Michael
______________________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On Oct 24, 2008, at 9:00 AM, <grass-user-request at lists.osgeo.org> <grass-user-request at lists.osgeo.org
> wrote:
> Date: Fri, 24 Oct 2008 01:04:01 -0700 (PDT)
> From: "Jana K." <jkrajc at gmail.com>
> Subject: [GRASS-user] Location wizard problem
> To: grass-user at lists.osgeo.org
> Message-ID: <20145981.post at talk.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> Hi,
> In grass 6.3 installed on Fedora 9, when I want to start a new
> location from
> the scratch, go through the Location Wizard, but at the end no
> location is
> created and I get the following messages on the console:
> File "/usr/lib64/grass-6.3.0/etc/wxpython/gui_modules/
> location_wizard.py",
> line 1475, in OnEnterPage
> self.lproj4string.SetLabel(self.parent.CreateProj4String())
> line 1874, in CreateProj4String
> return '%s %s' % (proj4string, proj4params)
> UnboundLocalError: local variable 'proj4string' referenced before
> assignment
> Does anybody have an idea how to solve this problem?
> Thanks,
> Jana
> View this message in context: http://www.nabble.com/Location-wizard-problem-tp20145981p20145981.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
