[GRASS-user] migrate entire location/mapset to new DB backend?
Dylan Beaudette
dylan.beaudette at gmail.com
Fri Oct 24 21:01:53 EDT 2008
On Tuesday 21 October 2008, Markus Neteler wrote:
> On Tue, Oct 21, 2008 at 6:01 PM, Dylan Beaudette
> <dylan.beaudette at gmail.com> wrote:
> > Hi,
> > Is there an elegant solution to migrating an entire location/mapset to a
> > new DB backend? I am thinking about moving all of the tables stored in
> > DBF to sqlite, however there are a lot of vectors-- and I was hoping to
> > avoid changing the connection and copying each one manually.
> > Ideas?
> Maybe I am missing something but isn't it as easy as
> - create new mapset
> - set SQLite or whatever with db.connect
> - run a "for" loop on g.mlist output, therein g.copy
> Ah, I see: we want this recursively for all mapsets in the location...
> Another option is to do it within the actual mapset, renaming first
> all maps to a temporary name, then db.connect, then g.copy
> locally to the previous name and removal of the temporary maps.
Right- that seems like the best solution for now.
> Since GRASS can be easily batch'ed, this could be done
> also for the entire location. Maybe Python would be more robust
> and portable at this point (yes, wanted for GRASS 7 to change
> to the new SQLite backend).
> Markus
I'll post a simple script, and then we can work towards making a more robust
version for conversions.
Cheers,
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
