[GRASS-user] Re: Export vect to shapefiles
Milton Cezar Ribeiro miltinho.astronauta at gmail.com
Tue Oct 28 10:51:43 EDT 2008
Hi GRASS-gurus,
I tryed the command again, using the GRASS MSYS console, and I noticed that
when my output command reach what I think is the "end" of task, the GRASS
don´t finish it. So, The command appear stay in loop, and it never finish.
And if I copy the files and try to open it on ArgGis - I really need it :-(
  - the ArcGis don´t understand the format.
Any suggestion?
miltinho
brazil
2008/10/28 Milton Cezar Ribeiro <miltinho.astronauta at gmail.com>
> Dear All,
> I am running native WinGrass and I am trying
> to export a vector map (with 100.000 areas).
> The command below is what I am using.
> v.out.ogr input=myvect dsn=c:/temp olayer=myexport type=area
> But after a all nigth long the command not finish
> and now update is done on the output files (which
> have about 80MB) since after 20minutes I start the command.
> Any help are welcome.
> Best wishes,
> miltinho astronauta
> brazil
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20081028/8646d7b1/attachment-0001.html
