[GRASS-user] Re: Export vect to shapefiles
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Tue Oct 28 12:13:18 EDT 2008
Dear Markus,
Thank your for your reply.
I agree completely with you. But I can handle a file with almost 4.500.000
polygons (=area?) on ArcGis. Have you any suggestion of how can I skipt this
trouble?
Best wishes,
miltinho
> 2008/10/28 Markus Neteler <neteler at osgeo.org>
> miltinho,
>> remember the 100000 areas - a non-trivial size.
>> Markus
>> On Tue, Oct 28, 2008 at 3:51 PM, Milton Cezar Ribeiro
>> <miltinho.astronauta at gmail.com> wrote:
>> > Hi GRASS-gurus,
>> > I tryed the command again, using the GRASS MSYS console, and I noticed
>> that
>> > when my output command reach what I think is the "end" of task, the
>> GRASS
>> > don´t finish it. So, The command appear stay in loop, and it never
>> finish.
>> > And if I copy the files and try to open it on ArgGis - I really need it
>> > - the ArcGis don´t understand the format.
>> > Any suggestion?
>> > miltinho
>> > brazil
>> > 2008/10/28 Milton Cezar Ribeiro <miltinho.astronauta at gmail.com>
>> >> Dear All,
>> >> I am running native WinGrass and I am trying
>> >> to export a vector map (with 100.000 areas).
>> >> The command below is what I am using.
>> >> v.out.ogr input=myvect dsn=c:/temp olayer=myexport type=area
>> >> But after a all nigth long the command not finish
>> >> and now update is done on the output files (which
>> >> have about 80MB) since after 20minutes I start the command.
>> >> Any help are welcome.
>> >> Best wishes,
>> >> miltinho astronauta
>> >> brazil
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
>> Open Source Geospatial Foundation
>> http://www.osgeo.org/
>> http://www.grassbook.org/
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20081028/ced13ba5/attachment.html
