[GRASS-user] GRASS 6.4 and Ubuntu Intrepid
Patton, Eric epatton at nrcan.gc.ca
Thu Oct 30 11:22:00 EDT 2008
>I did more testing about this problem, and I discovered this:
>- No, I haven't more then 1 version of GDAL or GRASS in my system
>- 6.4.0 and 6.2.3 report those errors while building:
>Errors in:
>/usr/src/grass-6.2.3/raster/r.drain
>/usr/src/grass-6.2.3/raster/r.fill.dir
>/usr/src/grass-6.2.3/raster/r.terraflow
>I'll repeat the test using an older GDAL, and let you know.
>Thanks
>Luca
I can confirm the same errors. I'm using a clean installation of
8.10, with all Grass dependencies installed through Synaptic.
(gdal 1.5.2, Grass 6.4 and 7svn installed).
Output from error.log:
GRASS GIS compilation log
Started compilation: Thu Oct 30 09:48:55 ADT 2008
Errors in:
/usr/local/grass6_devel/gui/wxpython/vdigit
/usr/local/grass6_devel/raster/r.drain
/usr/local/grass6_devel/raster/r.fill.dir
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Thu Oct 30 09:56:17 ADT 2008
The error with v.digit is related to the fact that it is not picking
up the self-installed wxwidgets package that I had to fetch. The default
wxwidgets version the ships with Ubuntu 8.10 is only version 2.6.3.
~ Eric.
