[GRASS-user] using grass on rasters without converting?
Glynn Clements
glynn at gclements.plus.com
Thu Oct 30 17:24:57 EDT 2008
Markus Neteler wrote:
> > I'm not too familiar with the WMS driver. But if it doesn't support
> > skipping rows then it is a bug and should be fixed. To file a ticket on
> > this issue it would be helpful if a demonstration of the problem could
> > be boiled down to a small C/C++ program or Python script just depending
> > on GDAL.
> > Adam Nowaki is the main author of the WMS driver.
> Unfortunately I am not skilled enough in Python to write down the
> requested test case.
Does "gdal_translate -outsize ..." work with WMS?
