[GRASS-user] Newbie question: Reclassifying raster (ndvi) using
fisher method
Edward Tomlinson
e.j.tommo at gmail.com
Fri Oct 31 20:47:55 EDT 2008
Hi all,
I am not sure as to which list this best fits (Grass or R-sig-geo).
I am trying to reclass a raster map (ndvi) into 5 different zones using the
fisher method, ultimatley i am trying to reclass as natural breaks.
The point of this exercise is for precision agriculture. I want to determine
management zones according to the current crop, so i can use this
information for inputs for next years crop. Therefore i have no use for a
range of ndvi values -1 thru 1. I need to split this into a number of zones
(5 or 7 is good number, unless i can get an algorithm to determine the exact
number of groups it needs). Each zone then in turn needs to be ground
truthed (hence need for classifying into 5 or 7 zones).
My problem at the moment is that the way i am doing it takes a while... I
would sure love it if anyone has any suggestions to speed up the process...
Is it possible to do the reclass bit in R and export the raster
(SpatialDataFrame) back into grass? I have read a post from Roger Bivand on
how to do the whole classinterval thing (thank you Roger) however i am
unsure of how then to create a new image from those values. I have looked
through the sp package breifly but I dont very well understand the R system.
Current method (this has to be done for each paddock, or paddocks can be
grouped if they have similar management history).
create ndvi
r.mapcalc 'ndvi=1.0*(nir-red)/(nir+red)'
move ndvi raster to R
-R-R-R-----------------
library(spgrass6)
G <- gmeta6()
ndvi <- readRAST6(ndvi at mapset)
library(classInt)
t1 <- classIntervals(ndvi$ndvi.mapset, n=5, style="fisher")
print(t1)
create text document for reclass rules, multiply everything by 10,000,000
(as reclass will round my numbers)
back in grass
r.mapcalc ndvi_10M = ndvi * 10000000
r.reclass input=ndvi_10M output=ndvi.reclass rules="rules created in text
doc" title="title"
I hope this all makes sense. Thank you for your time and reading through my
problem. If you have any suggestions i sure would be greatful.
Kind regards,
Ed
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20081101/e5ffd9f5/attachment.html
