[GRASS-user] BIN raster import
Hamish hamish_b at yahoo.com
Wed Sep 3 04:56:09 EDT 2008
Richard:
> Ahh - so there's an error in the UI, which says:
> Number of rows: (rows, float, optional)
> Number of columns: (columns, float, optional)
so there is. now fixed in SVN.
> It may be that rows and columns are floating point on the "inside",
they are really ints on the inside.
> but the UI should make it clear that integer values are required!
> I was trying to fiddle the row/column combinations up and down to
> get the file size right ...
no metadata with it?
sometimes the cell-center as coord versus grid confluences as coords
convention can cause the data to be off by 1 row/col from stated size.
Hamish
