[GRASS-user] supervised classification "no subgroup files
available"
Silvia Simoni
silvia.simoni at ing.unitn.it
Fri Sep 5 04:28:37 EDT 2008
Hi Markus,
As to the training area I draw just one, which is fearly small because
it's homogeous with rispect to the color I want to sample. I've tried
to select other areas in the same section, using the command "draw
region", but apparently I'm not allowed to do it.
I always close the training areas with the "complete button".
Here it's the procedure I'm following
1. i.group (to create group A and subgroup rgb)
2. d.mon
3. i.class map=ortophoto_composite group=A subgroup=rgb outsig=test (I
can see the file test being created in the folder .../subgroup/
$SUBGROUP/sig/; it's now 0 Byte)
4. from the interactive i.class menu, I select "Zoom"; then once the
zoomed area is displayed, "Define Region" and "Draw Region". I draw 1
area by points, then I click on "Complete Region" and "Done". As I
return to the main menu, I click on "analyse region" -> Signature
Menu, "Display matches", "Done". save Signature YES, then I'm prompted
for the signature description; finally I Quit from the main menu. Now
I can see the file size has increased to 14 Byte. When I edit it, I
can see only 3 lines.
I've also tried selecting a much larger area for which the histogramm
is smoother that in the previous case, nothing has changed, still 3
lines in the outsig file.
Thanks,
Silvia
On Sep 4, 2008, at 9:52 PM, Markus Neteler wrote:
> On Thu, Sep 4, 2008 at 6:24 PM, Silvia Simoni
> <silvia.simoni at ing.unitn.it> wrote:
>> Thanks Markus!
>> I'm now using grass6.4.svn but I still have trouble with the
>> supervised
>> classification process. Now I can run i.class and produce the
>> spectral
>> signature for my map but this file is NOT readable by i.maxlik. I
>> get the
>> following message: Can't read signature file [signaturefile].
>> I checked in $MAPSET/group/subgroup/$SUBGROUP/sig/; the
>> signaturefile is
>> there but it only contains 3 lines, as follows:
>> #comment
>> single value XXXX
>> Is this correct? I obtained other signature files from i.cluster
>> which look
>> different from this. It seems to me that i.class doesn't write the
>> signature
>> file correctly so that i.maxlik is not able to read it.
> It doesn't look good.
> But a quick test here didn't show any problem.
> Are you sure that
> - your training areas are big enough in i.class?
> - that you close the training areas with the "complete" button?
> Markus
Silvia Simoni PhD
DICA - Department of Civil and Environmental Engineering
Universita' di Trento
via Mesiano 77, 38100 Trento, ITALY
tel. +39 0461 882610
fax. +39 0461 882672
e-mail: silvia.simoni at ing.unitn.it
