[GRASS-user] R.in.wms on MacOS - bug?
Agustin Diez Castillo
Agustin.Diez at uv.es
Wed Sep 10 06:30:09 EDT 2008
I've never thought of this like a MacOS problem but maybe it is.
This does NOT work in grass:
r.in.wms -l mapserver=http://www.idee.es/wms/PNOA/PNOA srs=EPSG:23030
format=geotiff wmsquery=version=1.1.1 maxcols=1024 maxrows=1024
'wgetoptions=-c -t 5 -nv' 'curloptions=-C - --retry 5 -s -S'
method=nearest v=1
but this work from several browsers
http://www.idee.es/wms/PNOA/PNOA?service=WMS&version=1.1.1&request=GetMap&format=image/png&width=1200&height=800&srs=EPSG:23030&layers=PNOA&bbox=726000,4285000,727320,4285948
And this also works
r.in.wms -l mapserver=wms.jpl.nasa.gov/wms.cgi srs=EPSG:23030
method=nearest v=1
El Sep 9, 2008, a las 4:13 AM, Hamish escribió:
> Richard Chirgwin wrote:
>> R.in.wms seems to be stumbling on parsing inputs
>> First, errors occur which it attributes to cs2cs:
>> <cs2cs>:
>> projection initialization failure
>> cause: no system list, errno: 2
>> program abnormally terminated
> I have now updated r.tileset in SVN so it catches if cs2cs fails.
> (for example if the epsg file can't be found, as suspected for above)
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
