[GRASS-user] Export To PostGIS (with attributes)
Moritz Lennert
mlennert at club.worldonline.be
Wed Sep 10 12:02:29 EDT 2008
On 10/09/08 16:25, gridcell wrote:
> What I have been currently doing is...
> 1) v.in.ogr (import only geometry column from postgresql/postgis)
> 2) v.clean
> 3) v.out.ogr (layer 2)
> 4) In postgresql I run a point in polygon (PIP) on the table created in step
> 3)
> 5) Use the ST_Contains function with the original ("dirty") table to create
> another table of attributes, which includes the unique id from the spatial
> table.
> My result in the case of two polygons that partially overlap...
> Spatial Table Attribute Table
> gid wkb_geometry sp_id gid parcel_name ....
> 1 XXXXXX 1 1 Tom's Parcel
> 2 XXXXXX 2 2 Jane's Parcel
> 3 XXXXXX 2 3 Tom's Parcel
> 3 4 Jane's Parcel
What exactly do you want to make happen in the case of overlaps. There
is a fundamental difference between the PostGIS format which is
non-topological and the internal GRASS format which is topological and
which, thus, does not really allow for overlapping polygons. You can
digitize them, but they are not really useful...
> I was hoping that all the processing could have been done in GRASS rather.
You cannot directly process a PostGIS table in GRASS. GRASS has its own
internal vector format. If you want to do everything in GRASS, you have
to stop after step 2. You can link a GRASS layer to a PostgreSQL table,
though.
Moritz
