[GRASS-user] Errors with v.in.ascii with Strings
    Ryan R. Rosario
    uclamathguy at gmail.com
    Sun Sep 14 21:20:44 EDT 2008
I am able to import a CSV file containing two columns both of double
precision, but once I add in a third column (called 'name') of text with
arbitrary length, I get the following error:
"x column is not of number type"
The command I am using is as follows:
v.in.ascii input=data.csv output=incidents format=point fs=, skip=1
{columns=x double precision, y double precision, name varchar(255)} x=1 y=2
z=0 cat=0 --overwrite
There must be something in the text that v.in.ascii does not like. FWIW,
this third column contains street addresses. What could be causing this?
R.
View this message in context: http://www.nabble.com/Errors-with-v.in.ascii-with-Strings-tp19486076p19486076.html
Sent from the Grass - Users mailing list archive at Nabble.com.
