[GRASS-user] <sigh>Not this pest again!
    Richard Chirgwin
    rchirgwin at ozemail.com.au
    Thu Sep 18 02:00:52 EDT 2008
Hamish wrote:
> Richard Chirgwin wrote:
>> ... Having given up on the Australian Communications & Media Authority
>> DEM because it won't import into Grass-GIS (there seems to be some
>> fiddling to keep the DEM hidden behind a silly Windows app),
> with the exact file size, expected rows & columns, and possibly byte info
> and geographic extent known about it we still might be able to give some
> guesses about how to get around that. Or is it known for sure that they've
> taken steps to encrypt it?
I will, perhaps, contact you offlist on that angle...
>> I'm turning to other DEMs.
>> The NASA SRTM seems as if it would suit my purposes, except that using
>> r.in.srtm I get a lovely image with no elevation data. So r.what comes
>> up with latitude, longitude, and null, eg:
>> 150 | -34 | | *
> It probably worked, you just need to run g.region.
> I just tried:
> wget ftp://e0srp01u.ecs.nasa.gov/srtm/version2/SRTM3/Australia/S34E150.hgt.zip
Eeek. Yes, you're right, I forgot to run g.region at the end of the
import. All is fine, and excuse the coming snip...
[snip]
> Another way is get the data from Geoscience Australia's WMS server,
> if you look in the capabilities XML file you will see that geotiff is conspicuously missing from the available image formats:
>  http://www.ga.gov.au/wms/getmap?dataset=national&request=capabilities
> g.region n= s= w= e= res=...
> r.in.wms -l -g mapserv="http://www.ga.gov.au/wms/getmap?dataset=national&"
> I imagine GA are much more GIS friendly than the media censors.
However, you may recall that the DEMs that GA served up weren't true
DEMs - from an earlier conversation:
(as you remarked to me back in April)
Cheers and thanks for tolerating the dummy...
Richard C
> If you still have trouble with obtaining datasets, you might ask for help
> on the OSGeo Aust-NZ mailing list.
>> QGIS imports and displays the HGT file okay, but misinterprets the
>> elevation data as band data (so for Katoomba, 1000m above
>> sea level, QGIS says the band is 1004).
> no idea.
>> There aren't that many options in r.in.srtm, so I don't think I could
>> have gotten any of them wrong...
> probably it worked ok you just have to adjust the zoom with g.region.
> Hamish
