[GRASS-user] install grass with new wxPython user interface in
	Ubuntu (Solved)
    Jhon Ortiz
    eljhonjhon at hotmail.com
    Fri Sep 19 15:39:38 EDT 2008
> [cc list]
> Jhon Ortiz wrote:
>>>> But with this errors:
>>>> Errors in:
>>>> /usr/local/src/grass-6.3.0/visualization/nviz
>> When I type
>> cd /usr/local/src/grass-6.3.0/visualization/nviz
>> make
>> Give me a lot erros, but this errors is because nviz is
>> working with tcltk, and I compiled without tcltk.
>> I resolved that compiled with tcltk
> ok, it is already fixed in SVN that nviz will only build if Tcl/Tk is
> used:
>   http://trac.osgeo.org/grass/changeset/31328
> but 6.3.0 shipped before that change.
>> [...] and python
>> ./configure -with-cxx -with-gdal=/usr/bin/gdal-config
>> -with-postgres
>> -with-postgres-includes=/usr/include/postgresql
>> -with-postgres-libs=/usr/lib/postgresql/8.2/lib
>> -with-tcltk-includes=/usr/include/tcl8.4 -without-mysql
>> -without-odbc -with-readline -with-fftw
>> -with-fftw-libs=/usr/local/lib -with-freetype
>> --with-freetype-includes=/usr/include/freetype2
>> -enable-largefile -with-python
>> -with-proj-share=/usr/share/proj
> "-with-python" is not enough to get the new wxPython GUI installed.
> That is only required for the new vdigit.
> You will need to install wxPython 2.8 and friends.
> see grass-6.3.0/gui/wxpython/README
>> But now when I type in the terminal for start grass
>> (grass63 -wxpython), give me this error:
>>>>john at cito:~$ grass63 -wxpython
>> Cleaning up temporary files.....
>> Starting GRASS ...
>> Traceback (most recent call last):
>>   File
>> "/usr/local/grass-6.3.0/etc/wxpython/gis_set.py",
>> line 31, in
>>     from gui_modules import globalvar
>>   File
>> "/usr/local/grass-6.3.0/etc/wxpython/gui_modules/globalvar.py",
>> line 48, in
>>     CheckForWx()
>>   File
>> line 39, in CheckForWx
>>     except (ImportError, ValueError,
>> wxversion.VersionError), e:
>> UnboundLocalError: local variable 'wxversion' referenced before
>>  assignment
>> Error in GUI startup. If necessary, please
>> report this error to the GRASS developers.
>> Switching to text mode now.
>> Hit RETURN to continue...
> but the Tcl/Tk GUI works, right? and -text mode?
> $ grass63 -tcltk
> I think just the wxPython 2.8 packages are missing.
>> Thanks Hamish and all list
>> And sorry for repet the post, but is for answer the
>> question to Hamish.
> answers are good to have in the archives for others who search for the
> same error.
>> someone has an idea of how I can install grass with new
>> wxPython user interface in Ubuntu 7.10?
> If you wish to use the new wxGUI I would suggest to download the latest
> 6.4svn source code snapshot. The GUI has seen a lot of improvements.
>   http://grass.osgeo.org/grass64/source/snapshot/
> And see grass64.svn/debian/README.debian there for instructions on how
> to download Debian packaging rules from DebianGIS and build a .deb for
> your version of Ubuntu. (it is almost as simple as "dpkg-buildpackage"
> to create them using the automated scripts)
> or if you prefer just compile it yourself as you have been doing.
> Hamish
Just missing packages wxPython 2.8 and friends.
I just install these packages and now is working with Tcl/Tk, wxPhyton and text mode.
Thanks for your help Hamish.
John
_________________________________________________________________
¿Eres un cotilla? Disfruta de todas las novedades en MSN Corazón
http://entretenimiento.es.msn.com/corazon/
