[GRASS-user] Problems with OpenGL when compiling grass-6.4.0 on
Mac OS X 10.5.4
Elvis Dowson
elvis.dowson at mac.com
Sun Sep 21 14:32:55 EDT 2008
Hi William,
Ok, I've taken your suggestions and tried it, but with identical
results.
Here are my export option. I still get the same error without the -g
option
export CFLAGS="-arch i386 -Os"
export CXXFLAGS="-arch i386 -Os"
export LDFLAGS="-arch i386 -Os"
export NAD2BIN=/Library/Frameworks/PROJ.framework/Programs/nad2bin
./configure --with-cxx --prefix=/Applications/GRASS --enable-macosx-
app --with-x --with-cxx --with-opengl
checking for gluBeginCurve in -lGLU... yes
checking for glXCreatePbuffer... no
configure: error: *** Unable to locate .
I have attached the config.log file here. Please note that configure
command did not complete successfully. So, I haven't had a chance to
run make, so the glXCreatePBuffer() error is in the config.log.
Any ideas on how I can resolve this or what might be causing this?
Best regards,
Elvis Dowson
On Sep 21, 2008, at 10:20 PM, William Kyngesburye wrote:
> On Sep 21, 2008, at 12:20 PM, Elvis Dowson wrote:
>> Hi William,
>> Upon looking more closely at the config.log
>> configure:11340: gcc -o conftest -g -O2 conftest.c -lGL
>> 1>&5
>> ld: library not found for -lGL
>> collect2: ld returned 1 exit status
>> configure: failed program was:
>> I see that ld could not find the GL libraries for some reason.
> One thing to watch out for is the -g flag. This causes configure
> errors with the latest Xcode. export CFLAGS and CXXFLAGS with -Os
> before configuring.
> export CFLAGS=-Os
> export CXXFLAGS=-Os
> If you need debug symbols, add -g back into platform.make after
> configuration (to CFLAGS1 & CXXFLAGS1).
>> However, I have put this in my .profile. The location I have put is
>> usr/X11/lib . Is this the correct location?
>> # environment variables
>> export QTROOT=/usr/local/qt-4.4.1
>> export GRASS_TCLSH=/usr/X11R6/bin/tclsh
>> export GRASS_WISH=/usr/X11R6/bin/wish
>> export VTK_DIR=/Users/elvis/Tool/vtk-5.2.0/src
>> export VTK_LIB_DIR=/usr/local/lib/vtk-5.2
>> export X11_LIB_DIR=/usr/X11/lib
>> #export OPENGL_LIB_DIR=/Developer/SDKs/MacOSX10.5.sdk/System/
>> Library/Frameworks/OpenGL.framework/Versions/A/Libraries
>> # the path is initially set to "/usr/bin:/bin:/usr/sbin:/sbin:/usr/
>> local/bin:/usr/X11/bin"
>> export PATH=$PATH:$QTROOT/bin
>> export LD_LIBRARY_PATH=$VTK_LIB_DIR:$X11_LIB_DIR:$LD_LIBRARY_PATH
>> export DYLD_LIBRARY_PATH=$VTK_LIB_DIR:$X11_LIB_DIR:$DYLD_LIBRARY_PATH
> Setting DYLD_LIBRARY_PATH is unnecessary on OSX. If you have to do
> it for VTK, then the VTK build is broken. LD_LIBRARY_PATH is the
> linux version of this and is not needed on OSX.
> DYLD_LIBRARY_PATH only affects the finding of libraries at runtime,
> not linking as in configure tests. And properly built libraries on
> OSX should have the path built into them so they're found at runtime
> without DYLD_LIBRARY_PATH. Though GRASS does use this as a neat
> trick (as a side effect) to make the binaries relocatable.
>> Here is my configure command
>> app --with-x --with-cxx --with-opengl=aqua --without-readline --x-
>> includes=/usr/X11R6/include --x-libraries=/usr/X11R6/lib --with-
>> opengl-includes=/usr/X11R6/include
> This is probably what is confusing the build - you set --with-
> opengl=aqua, yet set the opengl includes and libs to X11. These
> options can't be used together. Configure should force the includes
> and libs based on the opengl value, but to be sure just use --with-
> opengl, which defaults to X11, and you probably won't need the
> includes/libs options.
> Also note that you need to compile your own tcltk for X11, and set
> those options for the GRASS configure. See the grass source osx
> readme for details.
>> If I use the -with-opengl=x11 option, I get the following
>> configuration error
>> checking for location of OpenGL library...
>> checking for glBegin in -lGL... yes
>> configure:10998: checking for location of OpenGL library
>> configure:11027: checking for glBegin in -lGL
>> configure:11044: gcc -o conftest -g -O2 conftest.c -lGL -L/
>> usr/X11R6/lib -lSM -lICE -lX11 1>&5
>> configure:11214: checking for gluBeginCurve in -lGLU
>> configure:11231: gcc -o conftest -g -O2 conftest.c -lGLU -
>> lGL -L/usr/X11R6/lib -lSM -lICE -lX11 1>&5
>> configure:11314: checking for glXCreatePbuffer
>> 1>&5
> This is strange - configure is inserting the X11 lib path for the
> glBegin and gluBeginCurve tests, but not for the glXCreatePbuffer
> test. Oh, I'm getting that also, but it's not keeping compilation
> from working. This is just testing for the availability of
> pbuffers, and GRASS has a fallback if that's not available.
> So, your make error log doesn't have the needed info. You need to
> look way back in the shell scrollback to see what the actual error
> is. You may need to change your Terminal window settings to
> unlimited scrollback.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
Skipped content of type multipart/mixed
