[GRASS-user] Problems with OpenGL when compiling grass-6.4.0 on
	Mac	OS X 10.5.4
    Elvis Dowson
    elvis.dowson at mac.com
    Sun Sep 21 17:05:17 EDT 2008
Hi William,
                       I think I know the reason for the glX linker
errors.
If I look at libGL.dylib in the /usr/X11/lib folder, it is actually a
symbolic link to /System/Library/Frameworks/OpenGL.framework/Versions/
A/Libraries/libGL.dylib whose size is only 568kb.
However, I can see that there is another file called libGL.1.dylib in
the /usr/X11/lib folder whose size is 2.3MB. Perhaps this is the
correct one?
How can I change the symbolic links so that libGL.dylib  points to /
usr/X11/lib/libGL.1.dylib instead of /System/Library/Frameworks/
OpenGL.framework/Versions/A/Libraries/libGL.dylib
Am I doing the right thing? Is there another way of ensuring that it
uses the larger 2.3MB version of libGL.dylib ?
Best regards,
Elvis Dowson
On Sep 22, 2008, at 12:53 AM, Elvis Dowson wrote:
> Hi,
>        I even tried changing the linker options to fix this, but no
> such luck
> export LDFLAGS="-arch i386 -Os -L/usr/X11/lib -lXm -lGLU -lGL -lGLw -
> lX11 -lXext -lXt -lm"
> What could be going wrong? Why can't the linked find the correct glX
> symbols?
> Best regards,
> Elvis Dowson
> On Sep 22, 2008, at 12:34 AM, Elvis Dowson wrote:
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080922/9c305c0c/attachment-0001.html
