[GRASS-user] error in grass 7.0 configure file
Glynn Clements
glynn at gclements.plus.com
Sun Sep 21 22:24:44 EDT 2008
Jarekj wrote:
> There is a problem with grass configure sript:
> checking whether to use Motif... yes
> checking for location of Motif includes...
> checking for Xm/Xm.h... no
> configure: error: *** Unable to locate Motif includes
Note that Motif is only used by xganim.
> while
> Xm.h is located in /usr/include/Xm
>From that compiler's perspective, it's more accurate to say that
<Xm/Xm.h> is located in /usr/include.
> and --with-motif-includes is added to ./configure command
> what is wrong??
You shouldn't be specifying --with-motif-includes= if <Xm/Xm.h> is in
/usr/include (as above).
> in earlier compilation (few weeks ago) --with-motif-includes wasn't
> necesarry
It still shouldn't be necessary.
Look in config.log for the actual error message.
