[GRASS-user] Attempt to export (r.out.gdal) produces sometimes an
	error and sometimes not
    Nikos Alexandris
    nikos.alexandris at felis.uni-freiburg.de
    Tue Sep 23 08:03:43 EDT 2008
> r.info composite_b123 -tr
min=0
max=32767
datatype=CELL
[Raster MASK present]
1st attempt to export:
 > r.out.gdal in=composite_b123
out=/home/nik/grassdb/peloponnese/data/exports/composite_b123.tif
Exporting to GDAL data type: UInt16
Segmentation fault
2nd attempt to export without any change:
Warning 1: Lost metadata writing to GeoTIFF ... too large to fit in tag.
 100%
WARNING: Input raster map constains cells with NULL-value (no-data). The
         value -32768 was used to represent no-data values in the input
         map.You can specify nodata value by nodata parameter.
r.out.gdal complete.
Shouldn't the same error message (from the 1st attempt) remain?
