[GRASS-user] r.digit. no zoom/pan option while digitizing ?
    Nagesh Bhatkar
    bnagesh at nio.org
    Wed Sep 24 01:57:29 EDT 2008
Hello Everyone,
I was looking to create a raster mask by hand using r.digit module.
The geocoded map is large and zooming is essential. There's no
zoom/pan option while digitizing. I have to zoom into part of the
raster map prior to running the module r.digit using d.zoom.
I have to exit the r.digit module after each segment of the mask is
created.
And then reset region to fit the entire map. And then display the
mask created and then select the next region to be zoomed in.
Create many masks and then patch them using r.patch.
I have gone through the archives,
It says, One can't force a running r.digit program to change the region it uses
internally. So one could change the region stored in the WIND file
using g.region, but that won't affect r.digit.
Is there any other way to create a raster mask!
Regards
Nagesh
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080924/b83b759f/attachment.html
