[GRASS-user] g.mremove error: "Argument list too long"
Rainer M Krug r.m.krug at gmail.com
Thu Sep 25 03:20:57 EDT 2008
On Thu, Sep 25, 2008 at 9:13 AM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 24/09/08 16:50, Rainer M Krug wrote:
>> On Wed, Sep 24, 2008 at 4:01 PM, Daniel Victoria
>> <daniel.victoria at gmail.com> wrote:
>>> Hi,
>>> How about separating it in smaller chunks.
>>> Try 3 comands first
>>> g.mremove -f rast=*
>>> g.mremove -f vect=*
>>> g.mremove -f region=*
>> That would not help much - all (except of a handfull of layers) are raster
>>> If you still get "argument list to long" you will have to split the
>>> rast/vect/region list once more. I don't know how your rasters are
>>> named but, for example, remove all that starts with the letter a
>>> g.remove -f rast=a*
>> That would be an option - but as it is used in a simulation, I don't
>> know for sure that not to many starting with a are created.
>> I therefore resorted to iterate through them:
>> for I in `g.mlist type=rast`;do g.remove $I; done
>> But in general, I would consider it a bug if an operation with
>> wildcard results in an error when to many are selected. I will file a
>> bug report for that.
> There is a C replacement of the current scripts in the GRASS 6.x and GRASS
> 7.x development branches (see e.g. [1]).
> Maybe you could just compile that and see if it solves the problem.
> [1]
> http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/general/g.mremove
> Moritz
Thanks - I'll do so on a later stage. For now I am iteratting...
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Faculty of Science
Natural Sciences Building
Private Bag X1
University of Stellenbosch
Matieland 7602
South Africa
