[GRASS-user] Re: v.dissolve Key column must be of type integer or
string
G. Allegri
giohappy at gmail.com
Thu Sep 25 17:09:12 EDT 2008
Solved. I was writing lowercase while the col name was uppercase.
I need some rest :-)
2008/9/25 G. Allegri <giohappy at gmail.com>:
> I don't know why the v.dissolve raises the usual error:
> "Key column must be of type integer or string"
> My column is of type CHARACTER. I've also tried to change it to
> INTEGER, but nothing happens.
> I've used the command many times before, but I don't remember if I've
> ever used it after recompiling my grass6_devel trunk (about one month
> ago).
> I'm trying to run it against a polygonal layer composed by three,
> confining, polygons.
> Giovanni
