[GRASS-user] Snapping Points to Nodes along Lines
Ryan R. Rosario
uclamathguy at gmail.com
Sun Sep 28 19:44:13 EDT 2008
I have one vector map consisting of 30831 points, and another consisting of a
road network. I have used the v.distance function followed by v.clean to
connect each point to the nearest road. I used the errors from v.clean to
obtain the intersections: basically, each point's projection onto a road.
#v.distance -p from=incidents to=roads out=connect upload=dist column=dist
#v.patch roads,connect,points out=patched
#v.clean patched output=patched_clean err=intersections tool=break,snap
The problem is, the error layer (intersections) only contains 6715 points
but for my next step I need to have the same number of intersections as data
points.
(In the next step, I want to take this layer of intersections (points) and
locate the nearest point in another layer along a road, so I need to have
the same number of intersections as I have data points)
What am I misunderstanding about the v.clean process? Is there some way I
can fix this?
View this message in context: http://www.nabble.com/Snapping-Points-to-Nodes-along-Lines-tp19716703p19716703.html
Sent from the Grass - Users mailing list archive at Nabble.com.
