[GRASS-user] Re: option multiple integer parameter problem
    G. Allegri
    giohappy at gmail.com
    Mon Sep 29 06:09:49 EDT 2008
I forgot to say that I'm using grass_devel6 from SVN Rev.32879
2008/9/29 G. Allegri <giohappy at gmail.com>:
> Hi list,
> I have some problems with integer type module parameters when the
> multiple is set to true.
> E.g. in r.univar_main.c:
> param.percentile = G_define_option();
>    param.percentile->key = "percentile";
>    param.percentile->type = TYPE_INTEGER;
>    param.percentile->required = NO;
>    param.percentile->multiple = YES;
>    param.percentile->options = "0-100";s
>    param.percentile->answer = "90";
>    param.percentile->description = _("Percentile to calculate
> (requires extended statistics flag)");
> the result is a flag box without text input. The textbox appears if I
> remove the "multiple" parameter.
> The same happens in bash scripts. Eg, if in v.rast.stats I set
> "multiple" the textbox disappear...
> Giovanni
