[GRASS-user] Problem grass-6.4.0 error setting region: child
	process exited abnormally
    Michael Barton
    michael.barton at asu.edu
    Mon Sep 29 18:34:55 EDT 2008
Could you please let us know the platform you are running on and where
your copy of GRASS came from (compiled yourself, binary from someone
else)?
Michael
On Sep 29, 2008, at 2:16 PM, <grass-user-request at lists.osgeo.org> wrote:
> Date: Tue, 30 Sep 2008 01:15:21 +0400
> From: Elvis Dowson <elvis.dowson at mac.com>
> Subject: [GRASS-user] Problem grass-6.4.0 error setting region: child
> To: GRASS User <grass-user at lists.osgeo.org>
> Message-ID: <097740D8-D779-43B8-869E-6A81FE4EE992 at mac.com>
> Content-Type: text/plain; charset="us-ascii"
> Hi,
>          I'm getting some errors when trying to use some basic
> grass-6.4.0 operations.
> I click on Add a Raster Layer and select the aspect file from the
> spearfish60 permanent dataset.
> After that I click on Display Active Layers and I get an error message
> "Error setting region: child process exited abnormally"
> -------------- next part --------------
> A non-text attachment was scrubbed...
> Type: image/png
> Desc: not available
> Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080930/e5a694f3/pastedGraphic.png
> After that I get an error message saying" Error can't read
> parts(projection)": no such variable
> Type: image/png
> Desc: not available
> Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080930/e5a694f3/pastedGraphic-0001.png
> If I click on the details button, I get the following error
> information:
> can't read "parts(projection)": no such variable
>     while executing
> "regexp -nocase {^([0-9]+)} $parts(projection) trash
> parts(projection)"
>     (procedure "MapCanvas::runprograms" line 46)
>     invoked from within
> "MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
>     (procedure "MapCanvas::drawmap" line 38)
>     invoked from within
> "MapCanvas::drawmap $mon"
>     (procedure "MapCanvas::display_server" line 9)
>     invoked from within
>     ("after" script)
> What could be causing it?  I just built grass-6.4.0 on Mac OS X
> 10.5.5.
> Best regards,
> Elvis Dowson
