[GRASS-user] v.dissolve and r.cost problems
Paolo Cavallini cavallini at faunalia.it
Wed Apr 1 12:05:13 EDT 2009
Hi all.
I cannot get a result from v.dissolve:
v.dissolve input=regiao at nuovo layer=1 column=REGIAO output=reg_diss
dbmi: Protocol error
Cannot open select cursor: SELECT cat, REGIAO FROM regiao ORDER BY REGIAO
Unable to open vector map on topology level 2
Table linked to vector map does not exist
Vector map not found in current mapset
This happens on a specific column. The same shp dissolves well with
fTools from QGIS.
Furthermore, I launched r.cost on a  295 rows, 378 cols matrix, and it's
taking > 1h, whereas I did the same previously and it ran in tens of
seconds.
 6.3.0.1-gfossit20090216-1
Any hint? Thanks a lot.
Thanks.
Paolo Cavallini: http://faunalia.it/pc
