[GRASS-user] Converting polygons to lines
supunmali
supunmali7 at gmail.com
Sun Apr 5 15:30:56 EDT 2009
Is that mean it is not possible?? I need the attribute data to do network analysis (e.g. optimal path). Pls suggest a method.
Well, if roads are polygons it colud be a problem.
if you don't need atributes of roads I sugest to convert polygons to
raster, run r.thin, and convert raster to lines. But in that way you
will lost road attributes.
supunmali pisze:
> I need to convert a road network in polygons to lines to do a network analysis.
> I converted polygons to line by using v.type.bl- converting boundaries to lines. Then instead of getting single lines, i'm getting border lines over the polygon that was there earlier (No polygon its now line data). I tried cleaning options in GRASS but it didnt work.
> Please provide me with guidelines on how to convert it to line data enabling to do network analysis.
> Thanks
grass-user mailing list
grass-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://n2.nabble.com/Converting-polygons-to-lines-tp2589231p2589760.html
Sent from the Grass - Users mailing list archive at Nabble.com.
