[GRASS-user] Error in sqlite3_step()
Moritz Lennert
mlennert at club.worldonline.be
Mon Apr 6 05:58:23 EDT 2009
On 06/04/09 11:41, Moritz Lennert wrote:
>>> Don't have time to look into this now, but it must be a problem in the
>>> special sqlite implementation in that script:
>>> if [ "$driver" = "sqlite" ] ; then
>>> #echo "Using special trick for SQLite"
>>> # http://www.sqlite.org/faq.html#q13
>>> v.info --q -c map=$GIS_OPT_MAP layer=$GIS_OPT_LAYER | cut
>>> -d'|' -f1,2
>>> | grep -v "|${col}$" > "$TMP.coldesc"
>>> # need to revert order:
>>> cat "$TMP.coldesc" | cut -d'|' -f1 > "$TMP.coltypes"
>>> cat "$TMP.coldesc" | cut -d'|' -f2 > "$TMP.colnames"
>>> COLDEF=`paste -d' ' "$TMP.colnames" "$TMP.coltypes" | tr '\n'
>>> sed 's+,$++g'`
>>> COLNAMES=`cat "$TMP.colnames" | tr '\n' ',' | sed 's+,$++g'`
>>> echo "BEGIN TRANSACTION;
>>> CREATE TEMPORARY TABLE ${table}_backup(${COLDEF});
>>> INSERT INTO ${table}_backup SELECT ${COLNAMES} FROM ${table};
>>> DROP TABLE ${table};
>>> CREATE TABLE ${table}(${COLDEF});
>>> INSERT INTO ${table} SELECT ${COLNAMES} FROM ${table}_backup;
>>> DROP TABLE ${table}_backup;
>>> COMMIT;" > "$TMP"
>>> db.execute input="$TMP"
>> My execute statement looks like this:
>> BEGIN TRANSACTION;
>> CREATE TEMPORARY TABLE SBC2_backup(cat INTEGER,LM CHARACTER,WARD
>> INTEGER,CLASS_NAME CHARACTER);
>> INSERT INTO SBC2_backup SELECT cat,LM,WARD,CLASS_NAME FROM SBC2;
>> DROP TABLE SBC2;
>> CREATE TABLE SBC2(cat INTEGER,LM CHARACTER,WARD INTEGER,CLASS_NAME
>> CHARACTER);
>> INSERT INTO SBC2 SELECT cat,LM,WARD,CLASS_NAME FROM SBC2_backup;
>> DROP TABLE SBC2_backup;
>> COMMIT;
>> Why does v.db.dropcol define a type CHARACTER when sqlite3 supports
>> (NULL, INTEGER, REAL, TEXT, BLOB)?
> v.db.dropcol just uses the output of v.info -c, and AFAIR, SBC2 has its
> columns defined as CHARACTER, or ?
See also this thread:
http://lists.osgeo.org/pipermail/grass-user/2009-January/048281.html
Moritz
