[GRASS-user] Grass and Postgre limitation (if any)
    Jarek Jasiewicz
    jarekj at amu.edu.pl
    Mon Apr  6 12:53:52 EDT 2009
I still don't know about the limit but I reached the number of 1000 for
mapsets and 10000 for tables which is enaugh for me
Thanks for useful hint
Jarek
Moritz Lennert pisze:
> On 05/04/09 19:10, Jarek Jasiewicz wrote:
>> Hi
>> I have short question.
>> I'm prepraring to create huge dataset, where data for different
>> regions will be stored in different mapset but with the same
>> structure of data (names of files and so on). The number of planned
>> mapset is about 200-230, with about 10 postgreeSQL tables in every
>> mapset. IT gives about 2000-2300 tables in one database. Tables will
>> be use datatypes unique for postgreeSQL contribs so different databes
>> solution cannot be used.
>> The question is is some of the numbers above are not close to these
>> program limitation (i.e number of mapset) or number of tables
> I'm not sure for GRASS, but I think that in both cases the limits will
> be mostly defined by your OS (i.e. max number of sub-directories or
> max number of files), and not by the program.
> You can try it out in a test location, loopping through g.mapset -c
> commands to see whether you reach a limit at one point.
> Moritz
